メインコンテンツにスキップ
2.5GHzデュアルコアIntel Core i5プロセッサ(Turbo Boost使用時最大3.1GHz)、3MB共有三次キャッシュ
265回答 すべてを表示
No wifi/Bluetooth, no power to rightside USB after battery replacement
Hello everyone,
I have recently replaced the battery using the ifixit toolkit on my late 2012 rMBP 13” running MacOS Catalina. While that seems to have been successful and the MacBook powers on without issues, wifi and bluetooth no longer seem to be working. Furthermore, I don't seem to have power to the right side USB port (could be the whole side).
I have performed an SMC reset and reset PRAM without any success, which makes me believe it is a hardware issue. I/O board data cable perhaps? Opened up again and checked over everything, but nothing seems to be out of order or visibly damaged.
Update (06/03/2020)
Problem solved. Will mention in case someone has this issue in the future.
The I/O board data cable connectors had been deformed somehow during my disassembly. Notably, the data cable fit just fine even though the connectors were deformed. I used one of the fix kit tools to bend the connectors back to their original shape/position and everything is now back to normal. It's definitely a part that needs to be paid attention during assembly/disassembly.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Check the I/O board and its cable MacBook Pro 13" Retina Display Late 2012 I/O ボードの交換
The Airport is mounted to it and this can also explain why your USB port is also failing.
MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cable
MacBook Pro 13" Retina (Late 2012-Early 2013) Right I/O Board
MacBook Pro 13" Retina (Late 2012-Early 2013) Right I/O Boardの画像
製品
$49.99
MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cableの画像
製品
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
bgdimitrov さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 238
