メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年4月に発表・発売された第2世代iPhone SEの修理および分解情報。
iPhone SE2 and iPhone 8 Frame interchangeable?
Hi guys,
Does anyone know where to purchase an SE2 frame from? Does it fit in an iPhone 8 chassis as customer has smashed front and rear, but cannot source a replacement frame.
Has anybody successfully moved the internals to an iPhone 8 Chassis? The customer is happy with this solution - if it can be done :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
I don't think the iPhone 8 frame will work for a se2. The mounting for the motherboard is different I believe.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Thanks Allan, looks like a new screen and case for now then!
さんによる
A bunch of parts are interchangeable though.
さんによる
By the sounds of it almost everything except battery and lb. Rear camera also but with a difference to picture quality.
Shame about the frame as I have no way of getting that part in
さんによる
I believe the camera is the same but the difference in quality is from the compute power of the new chip. I checked every place I deal with and can't find a back case yet. Give it a month or two.
さんによる
コメントを追加
Mostly people think so that both have same frame/chassis/ housing. I am seeking for the right experience and answer.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have done it on my own iPhone SE2 after the rear glass broke. I found it easier to pay $20 for an entire iPhone 8 chassis than to fool around with picking off the glass shards. The swap works wonderfully, though the procedure requires stripping every part and keeping track of the screws. I also have some doubts about the quality of mobile reception (battery goes down pretty quickly), but that might be unrelated.
I do not understand why people answer these questions with "I don't think" or "Mostly". Either you know or you do not. I have done it, so I know it is possible.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
EPR さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 32
今までの合計 2,011
