メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
iPhone 6s home button not working after screen replacement
Hi all,
I got a very strange problem on my iPhone 6s. My original screen broke, so I replaced the screen. After the replacement the home button is not working, neither the clicking or touch id. I put back the original screen and the home button was working on the broken screen.
I tried 3 different 6s screens and on no one worked the home button, only on the original screen. The screens are bought from different sellers so they are not the same.
What could be the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
It has to be the screens. If it will work on the original screen but not the replacement screens and you have transferred the original home button to the the replacement screens and they are connected correctly then the only problem is the screens you purchased. I would find a higher quality screen and try it. Ifixit sells them.
Update (05/24/2020)
That's a lot of work and might not work and he will lose the warranty on the screen. I have put on quite a few screens on and have only has the issue that I had a defective screen twice. It will happen with electronics. In my opinion he just needs to buy a high quality screen and he should be fine.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Could it be that the iPhone only accepts OEM screens?
さんによる
コメントを追加
The original home button cable from the damaged screen can be reused with the new replacement screen. If some heat is used, the backlight layers can be taken apart, starting with the metal plate/mirror which has the home button cable enclosed inside. The process will be similar to this:
https://www.youtube.com/watch?v=01ecUhWS...
I highly recommend practicing this on a damaged screen first. Depending on what is replaced, the backlight LED power cable will need to be soldered as well.
Best of luck!
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
But I think that should not be the solution. I got again a new screen from another shop and again the home button is not working. The home button works only on the original screen.
さんによる
It might be a poor connection to the logic board. Try adding some extra padding to the flex cable before screwing down the shield.
さんによる
I tried but without success. This is very strange and really don't know what to do...
さんによる
コメントを追加
回答を追加する
Uas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 193
