メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
無停電電源装置 (UPS) は、停電やその他の電源トラブルが発生した際に、重要な機器へバックアップ電源を供給する電気機器です。
Zebronics UPS not working.
My UPS,Zebronics ZEB-U725 UPS is not working when there is no main supply. If I switch it on when there is no main supply, momentarily voltage comes on its out put socket (Which can be seen by a volt meter only) then shuts down, even when load is not connected. I checked the battery voltage. It is about 11V. When I switch on the UPS the battery voltage comes slightly down ie it comes down to about 10.5V, then returns to 11V as the UPS shuts down. Please suggest solutions.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Hi @ pvr59ksl
How long the UPS is in service?
Is the UPS still under warranty?
If so, send in for repairs.
else you need to check and inspect the internal main board .
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
Hi,
When power is connected there should be 13.8V across the battery terminals as this is the voltage necessary to maintain the battery fully charged.
When the power is disconnected and with no load, a good battery will measure 12V. If you only measured 11V then the battery may be failing.
Given that the voltage falls quickly to 10.5V under load, it seems to indicate this. The voltage may be falling even quicker and it gets below the minimum battery voltage threshold for the UPS, so it shuts down.
How old is the battery and how often and for how long is the UPS utilized due to power outages?
If there is approximately 13.8V across the battery terminals when the power is connected then perhaps you should try replacing the battery. Ensure that the replacement battery is fully charged, (unless you know that it is fully charged when you get it) and then check the UPS operation
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
pvr59ksl さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 37
今までの合計 3,074
