メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola Moto Z Play (モデル番号XT1635-02, XT1635-01,XT1635-02)は2016年9月に発売されたスマートフォンです。Moto Z Play機種の見分け方はデバイスのフロント下側のスクウェア型ホームボタンとフロント上側に“moto”というサインが入っています。
How to remove stripped screws?
Hello, I am trying to replace a battery on the moto z play phone. I got the back off and screen separated. But can not get the little screw out to remove the metal piece holding the battery cord in place. Anyone have a suggestion on removing stripped screws? I have tried the rubberband trick but no luck.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Have you tried other screwdriver bits of different sizes and shapes? If that does not work you can carefully drill into the screw till the head comes off with a very tiny drill bit (see pin vise from here or amazon). Of course with this method you will have to replace the screw.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
That was not pretty. I ended up drilling the screws and doing my best to break off the top….which was challenging. I tried the rubberband trick and I think they were to far gone. The super glue did not hold and would just pop off. And then I even tried soldering the screw……nothing.
Anyway, I got the screw heads off and was able to move on.
Thank you for your responses and help. I greatly appreciate it. I am new to this….so lots of trial and error.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi Melissa,
A couple of options with stripped screws, drilling is an option as Josh mentioned, but first, to drop a little super glue into the screw, then pop the driver in, wait a few mins then twist out.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Melissa Odom さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 23
今までの合計 723
