メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Latitude E5530は、Windows 7 Pro 64ビットを搭載し、耐久性の高いバッテリーを備えたノートパソコンです。重量は2.27kg(約5ポンド)で、デュアルコアのi5 CPU、4GBのRAM、非常に快適なキーボードとトラックパッドを搭載しています。
Computer running too slow
I have a latitude e5530 running Windows 7 Pro with Intel Core i5, and it runs very slow. I start up the task manager, it only uses about 8% of the CPU on average. There is also something wrong with the speakers, there is usually either no noise or it is very faint. I put the volume to 100% and nothing changed. Is there a way to fix these problems?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
ベストアンサー
Upgrade hard drive to SSD. This will improve performance.
Upgrading to Windows 10 would also spped it up. It is still a free update with legit W7, as far as I know.
I would especially think this with Task Manager showing only 8%. The old hard could possibly be ready to die.
What temperatures are CPU, etc.?
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
How would I be able to see the details you ask for? I can't find the CPU temp in the Task Manager
さんによる 共有
Do you know how to get to hardware monitor? it is a free software that can check temp, and other things etc.
さんによる 共有
What's their site?
さんによる 共有
@sjhralbert
Sorry have been doing TAXES for last few days.
https://www.cpuid.com/softwares/hwmonito...
さんによる 共有
さんによる 共有
コメントを追加
Try cleaning the speaker. It helps with the noise. Take the speaker out of the computer, and brush off anything.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Well, since this is a 11-year-old model, you have to take off the motherboard and all to see the speaker itself.
さんによる 共有
And what about the slowness problem?
さんによる 共有
No, for the speaker. I forgot that it...
さんによる 共有
コメントを追加
All Dells have a Service Tag (like a serial number) on them. For that model, it will be on a sticker on the bottom, possibly under the battery. If you can find it, write it down.
Then, go to Dell’s, website here: https://www.dell.com/support/home/en-us/...
If found the Service Tag I mentioned, type it into the Dell website. This will give you all the system’s details, including how it was configured when it was originally built.
Regardless, all of the Dell software mentioned above can also be found on the same website, two tabs over. Or here: https://www.dell.com/support/home/en-us/...
Finally, this is everything you’ll likely need to dial that Dell back in (also on Dell’s website) https://www.dell.com/support/article/en-...
HTH
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
To fix the fan problem try cleaning the fan and shooting some air at the whole thing and for the speakers try looking where the connect cause they could be loose
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The whole thing meaning the whole computer
さんによる 共有
コメントを追加
I fixed the speaker problem, apparently there was something wrong with my headphones. I used another set of headphones and the audio sounded as crisp as it used to.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Albert Einstein さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 32
今までの合計 1,351
