メインコンテンツにスキップ
モデル番号A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5もしくは3.5 GHz Core i7 Processor, ID iMac14,2
340回答 すべてを表示
How to know if Power Supply is okay?
The computer doesn't power on. It only shows a solid green light in LED#1
The power supply makes tick noises and the noises change when I press the power button.
I would like to know how can I test it with a multimeter? I'm planning on buying a new MB because this one has a blown part but I don't want to buy a new MB and have a bad PSU kill it.
Here is a video to check out the sounds and the burned part: https://www.youtube.com/watch?v=LK7_qJPd...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
A ticking noise is a coil or transformer in the power supply.
I would first replace the power supply before trying a new logic board.
このアンサーは役に立ちましたか?
スコア 1
11 件のコメント:
I will record a video of the sound and post it on YouTube. I'll post the link here. Give me about an hour or two.
さんによる
@pigoath - No need, I've had a few tickers across my bench ;-}
さんによる
I will be uploading the video anyways. I would really appreciate if you could check it out. I want to know how to test the PSU with a multimeter to know if it's giving me proper voltage or if the problem is the MB.
By the way, is it normal for a PSU to make ticking sounds? I guess not?
さんによる
No, the power supply doesn't tick! You have a bad coil or transformer within the power supply assembly.
さんによる
6件以上のコメントを表示
コメントを追加
回答を追加する
Pigoath さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 122
