メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年4月に発売されたXiaomi Mi Mix 2Sスマートフォンの修理ガイドです。
Front camera not working after screen replacement
Hi. I replaced my Mix 2S cracked screen with a replacement off ebay. The replacement went without a hitch, managed to replace it without breaking anything else or losing anything.
Some time later I realised that the front camera wasn’t working. Figuring I had a loose connection I took it apart again and reseated the camera flex and retried but still i would not work.
I ordered a new camera flex and when it arrived I replaced it and still the issue was the same.
When I open the camera app and press the icon to switch to the front camera it just switches between the two rear cameras which both work perfectly.
There are no errors or anything I can find. Do you have any idea what the problem could be?
I have sent the replacement screen back to see if a new one will make any difference. In the mean time I figured I’d ask on here.
Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi,
I have the exact same problem. Did you manage to find a solution?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Me too.. same exact problem. Just changed my screen and frontal does not work anymore.. welp?
さんによる
コメントを追加
回答を追加する
Pete さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 19
今までの合計 792
