メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HPが販売する14インチノートパソコン、HP Elitebook 840 G2の修理およびトラブルシューティングガイドです。
Trying to change the SSD
I am trying to change SSD due to the original having limits and being blocked. Tried replacing with two separate and neither seem to register or work.
Original works, so I was wondering where I was going wrong
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Hi,
What capacity and type of SSD were you trying to install?
Were they being detected by the BIOS?
Here's a list of the SSD that should work in your laptop. Scroll down past the RAM module list to find the SSD list
さんによる
If you connect them to another computer, are they registered as a usable drive? Try formatting the drives, or activating them in Disk Manager.
さんによる
コメントを追加
1 件の回答
A brand new SSD is required to be formatted before use. It is suggested to use an external USB Disk connector to connect the new SSD to your PC and format it before use. You can either create different partitions or choose to keep the SSD as a single disk.
Post format it’s ready to use as an external disk or internal disk to install OS and all.
However, if you find it hard to connect the SSD using external port then it might be some hardware issues and you may need a new replacement.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
CTBlurry Games さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 484
