Laptop Keyboard not working
One day, I was going to go and play csgo on my laptop and my keyboard is no longer working, but is lit up. I really need help.
edit: I just a notification/answer and I tried it but my keyboards name wouldn’t pop up.
If your Asus keyboard driver is faulty, the Asus laptop keyboard not responding issue could crop up. You could uninstall it first and then reinstall it.
Step 1. Right-click Start and click Device Manager.
Step 2. Locate Keyboard and expand it.
Step 3. Right-click on the keyboard name and click Uninstall.
Step 4. Reboot your PC and Windows will reinstall the keyboard driver for you automatically.
If the above method works for nothing, otherwise check out post Methods to Fix Laptop Keyboard Not Working.
Make sure try one by one until it is working.
このアンサーは役に立ちましたか?
After doing so much on the laptop via onscreen keyboard I actually took keyboard off the laptop. Saw that the connector strip had come loose. There is one for the mouse pad bit too. I had black screen of death. Had to open it. Blew out fluff. Got it oing but keboard didn't work afterwards as I'd disconnected the strip when I opened it. Connected again and now working
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 8
過去 30 日: 29
今までの合計 11,287
1件のコメント
did you fix it?
i changed the keyboard it was a mess but still not working I think its something in the mother board, =(
Daniel de la garza さんによる
