There was something rattling in my controller and this came out.
Where is this piece supposed to go? It fell out when I opened it
You may check out all these teardown and replacement tutorials, as I can see that the metal component can only be attached to the controller board, you may try your luck and find it there.
https://www.youtube.com/watch?v=5P0Seo7e...
ガイド
難易度:
中レベル
10 - 25 minutes
ガイド
難易度:
難しい
30 minutes
このアンサーは役に立ちましたか?
The piece that fell out was plastic, it probably looked metal due to the lighting. I will check out the teardown videos and see if they can solve my issue.
@logibeak Did you reassembly it again? Will it work?
Is this the part that go on the side of the analog stick module where the joystick button is ?
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 5
過去 30 日: 13
今までの合計 761
