Which screws does MSI gs63 use?
I want to replace my MSI laptop screws because they are broken.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
From what I can find it is M2.5 x 6.5mm, Phillips Head #1 screws.
It sounds like the screws are stripped, so this guide may help you get them unscrewed if you have a hard time doing so.
Hope this helped! :D
このアンサーは役に立ちましたか?
Thanks you !! I will try it immediately.
No problem and good luck! :D
hello from france is it okay with Msi GS66 ?
過去 24時間: 1
過去 7 日: 12
過去 30 日: 44
今までの合計 5,538
2 件のコメント
What screws are you wondering about? The ones for the bottom cover?
Erik Eriksson さんによる
Yes, the first ones that you need to remove. @eke0909
Jiahao Cheng さんによる
