メインコンテンツにスキップ
MacBook Pro 16インチの解体情報と修理ガイドです。2019年11月に発売されました。モデル番号はA2141とEMC3347です。
211回答 すべてを表示
How to setup digital audio output on this newly released MacBook Pro?
Have this newly released 16” MacBook Pro laptop for a few weeks, love it so far. However, when try to use the optical audio cable connect to my 7.2 channel receiver(from earphone jack port), there is no sound at all (I can see there is “external headphone” shows up from “sound” icon). The audio cable works on my old MacBook Pro 15 model, so, no clue if Apple just disable this feature on 16” model, anyone has similar experience or know solutions?
thanks,
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
The headphone output of your Mac already has a very capable DAC. But if you want to get a pure digital signal all the way to your amplifier/receiver for its (probably better) DAC to handle it onboard and skip any potential analog interference along the cable path, look for a USB to TOSLINK or SPIDIF adapter. The DAC function only needs to happen once, and it is best that happens as close to the output as possible.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Sorry this series doesn’t offer a digital output.
さんによる
コメントを追加
最も参考になった回答
Sorry guy, Apple dropped the digital optical connection, which is why you won’t get a signal. If you need to gain it you’ll need to use a USB DAC unit.
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
Good to know, thanks!
さんによる
@lovecd - The 2012 models forward dropped the dual ports for both input and output. Apple had a lot of problems with the dual audio jacks which is why they dropped it. It was a good idea and I know a lot of people miss the connection in the newer systems.
さんによる
Is there a way to get the digital audio sound on this model, such as through USB-c to digital audio port?
さんによる
Thanks, that helps!
さんによる
2件以上のコメントを表示
コメントを追加
Theres a way to get digital from every macbook, they vary, but in the new ones its as simple as a DAC with USB, if your DAC doesn't have USB I would bet my right testicle you can get a device that can muster up a digital output from somewhere, as another way to digitally output you can use a USB-C to HDMI adaptor, then get your digital signal from that, as its all included in HDMI. sure there's probably other ways to if you get creative but you get the idea...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks, ended up getting an external sound card to do the job for me. Creative X4c sounds lovely :)
さんによる
コメントを追加
So does that bring the digital out? MBP16 already has a built in DAC according to their support page and says you dont need an external DAC. I am curious how an external DAC Will help with the situation?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
because it sounds better!
さんによる
A Digital-Analog Converter (DAC) is needed in all computers!
The quality can be an issue (often linked to the price of the system).
Apple has made a large investment in both the DACs they use, but also the speakers and even the microphones! So the systems sound output is much better than years past.
But! Getting that great sound out to a deck is a bit tricky! All you have is the analog input/output which can pick up noise (hum) to over come that you need to keep the output in a digital form. This is where an external DAC is needed and via a USB-A or USB-C connection. Then what you connect to and the sampling rate desired can define the next connection be it a high gain balanced headset via an analog COAX connection, an optical connection via TOS, even a direct USB-C headset.
さんによる
コメントを追加
回答を追加する
Tom さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 33
過去 30 日: 127
今までの合計 17,117
