メインコンテンツにスキップ
Repair guides and support for your LG TV.
1343回答 すべてを表示
LG logo flashes on, then black screen, ticking sound with remote use
LG TV powers on, gives a brief flash of logo on the screen (white lights flash briefly when back of TV is off), then black screen with no backlight (cannot see menu or anything with flashlight test). Standby red light remains on. Interesting thing ( not mentioned on other posts with this issue), Is that if I then use the remote control to try to get the menu to display, it starts making a quiet but constant ticking sound. I'm hoping that bit of information may help guide me in the direction of which part needs to be replaced without taking apart the entire thing. Have taken off main board, power board, TCon board and reattached. Nothing obviously abnormal looking. Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi @basco ,
What is the model number of the TV?
さんによる
Model # is LG 50UH5500. Thanks!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @basco
In my experience this issue is most likely related to a failed backlight array. Replacing all of the LED backlight strips should fix this problem.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi @basco ,
Just to add to this answer here's a video that shows the exact problem that you've described for your model and how to fix it.
さんによる
コメントを追加
回答を追加する
Basco さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 29
過去 30 日: 83
今までの合計 4,243
