メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年11月に発売されたLG製のスマートフォン。
Restoring data from a dead phone?
I’ve looked online a bunch but none of the things I found helped.. The phone has been dead for years, found it recently during cleaning. I know there are a ton of memories on it. Also, I THINK the phone model is correct.. it’s been years, but I’m 85% sure the one on the picture is identical.
When i plug the phone into my PC, it is detected.. but not recognised. Does a nonstop loop of connect noise-disconnect noise-device not recognised notification. Cannot turn it on at all, not even a screen lit up. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi
Try replacing the battery -example only and see if the new battery will start to charge.
If it does start charging, allow it to charge >80% before attempting to turn on the phone.
It may be that the depleted/dead battery is causing problems with the power needed to start the phone i.e. trying to charge a dead battery and turn on a phone at the same time.
It’s a small enough gamble
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'm afraid this is beyond battery issue.. The phone used to work on cable charge alone, without any battery.
さんによる 共有
コメントを追加
回答を追加する
f.karvay さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 29
今までの合計 324
