How to replace the battery?
How to open the back cover and replace the battery?
Hi @bamboo ,
To replace the battery you need to remove the LCD screen, as the battery is mounted on the back of the mid frame which is screwed into the back cover from the front.
Here’s a video that shows the teardown of the phone.
From about 2:30 minutes onwards in the video (after the screen has been removed), you will see how to get to the battery.
このアンサーは役に立ちましたか?
Hi jayeff,
Many thanks for your advice.
Battery replaced and new one seems to be holding charge.
Regards,
bamboo
過去 24時間: 1
過去 7 日: 4
過去 30 日: 34
今までの合計 4,700
