メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Latitude E5400 ノートパソコンは Intel Core 2 Duo T7250 / 2.0 GHz プロセッサを搭載し、1280 x 800 (WXGA) の最大解像度を持つ 14.1 インチスクリーンを備えています。
Why is windows 7 always crashing
So i have this dell latitude E5400 so its windows 7 ultimate we bought it at 2012 for me by my dad i know its old but it works perfectly si my dad bought disks for installation of windows 7 rog (custon made OS) it works perfectly then i installed minecraft at it it works fine but moving is a bit laggy tho i got a little carried away by playing the laptop itself overheated then the next day it works still fine but because of school i have to upgrade it to windows 10 because of alot of homeworks i didnt have time to use it then one year later (its 2020) i turned on my laptop and booted windows 10 then i played minecraft about 2 hours later my laptop suddenly shut down and restarted then i got a warning thing i guess it says “no bootable device detected please reseat hard drive”. Then i did what is says soo i opened the cover and put it out and put it back again after that it booted fine and another 2hrs it happened again.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @justalvin
I would suggest you to do diagnostic test.
I think this model dell has a diagnostic test inbuilt
When you power on the computer press F12… check for any diagnostic options…
or perhaps ….
Press D  + Power Button For Diagnostic
Press FN + Power On
check especially on the hard disk
if hdd is having issues, suggest you to get SSD for a long term replacement and excellent performance.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
OP needs a SATA II compatible SSD for this - the Fixed III drives don't work in this as it's a SATA II system. Should also support SATA I just in case.
さんによる
コメントを追加
回答を追加する
Alvin Gabriel Mendizabal さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 361
