after Upgrading my iMac 2019 the microfon did not work
after Upgrading my imac 2019 the inbuild microfon did not work..
I didnt remember what connector it was ?
have you any idee
この質問は役に立ちましたか?
have you any idee
この質問は役に立ちましたか?
The microphone is well hidden!
What happened is when you put the adhesive strip down you plugged the hole in the case covering the microphone.
Here’s more details on properly installing the display iMac Intel 21.5インチ Retina 4K Display (2017) 接着ストリップの交換
このアンサーは役に立ちましたか?
Is this the same with the 5k iMac?
@veenenen - Yes!
In my case i messed up real good.. the microphone in my 27 inches 5k 2019 is broken after upgrading the ssd.
the ribbon is very fragile
any idea how i can find the part?
Thank You !
このアンサーは役に立ちましたか?
Did you fix it? I just ordered one from thebookyard.com, hope it works flawlessly
過去 24時間: 1
過去 7 日: 7
過去 30 日: 38
今までの合計 1,808
