stuck in reboot loop
Cant turn on or off, it is stuck in a reboot loop, suspecting possible drainage,
been put inside the toilet for a while
Yes, water damage usually comes with a reboot loop. Don’t give up.
Firstly, if the motherboard is OK, check whether the Flex Cable is the cause as it may be corrupted in this circumstance. Replace it if it’s damaged.
Since the effects of water damage on phone is long lasting, you’d better consider transferring important data out of the memory to another devices.
If you fail to access its memory, then you will need some special tools to recover files from your android. You can find many such tools on internet.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 681
