メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
TBK 958c レーザーは、ガラスへの彫刻や、iPhoneのバックプレートガラスを固定している接着剤の除去に使用できる多機能なリペアツールです。
TBK 958A missing iPhone 8 file. How to find...
I got my laser back glass removal machine to make a successful run the first time around on a test iPhone 8 cracked back glass and it worked fine.
But the second time around when I try to select the iPhone 8 file nothing appears. Is there any way I can recover this file somehow?
Does my TBK 958c have a software issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
5 件のコメント:
Idem - stesso problema iPhone 7P
さんによる
تم إعادة تعيين وتم كسر الجهاز
さんによる
hello i need 13 p m laser software can;t dawnload
さんによる
hi please i need new update file remove back glass iphone laser machine thanks
さんによる
hi please i need update file remove black glass laser machine thanks
さんによる
コメントを追加
2件の回答
You save change file but you can download file from:
http://www.shenwangda.com/en/h-col-125.h...
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Hi Stad.
I did for a saved change file I messed up, and it worked great. BUT, the file for the iPhone XS MAX is not working from this download. The laser is missing the bottom corners of the phone.
Do you know how I can work around this issue? Or, is the file set specifically this way so the laser does NOT hit those lower corner sections on purpose?
さんによる
Hey, I don’t know if you ever found the answer you were looking for, but I found the treasure trove of files from the company. Most likely after use something got edited with the original file and it broke it. Here’s the link to the files. You want the one with 3.0.zip in the name.
さんによる
hi i have a problem with the laser machine is that it does not give the correct size when choosing a specific shape for a mobile device
さんによる
the new 3,0 from the shenwangda website is .lmf3.
i have the full 2.0 with all templates before the 3.0
contact me on smurfos76@gmail.com if still needed
さんによる
I have a tbk958f blue laser machine, but I could not retrieve the lost files. Can I retrieve the files?
さんによる
コメントを追加
Yes I am tray so need files
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
strelok さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 23
今までの合計 9,881
