メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Toshiba 40PB200は、PB200シリーズの40インチ薄型テレビです。2012年に発売されました。
There are vertical lines
Today my lil bro shot my tv with a bb gun and the tv had verticle lines where the bb was shot, is there any way i can fix it at home?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
From what you’re saying it appears that the screen has been damaged.
The screen cannot be repaired, it has to be replaced.
Post some close up images of the screen to show the damage just to verify if this is the case.
Here’s how to do this on ifixit iFixitでの質問に画像を追加する方法
You will need to find the part number for the screen to make it easier to find the correct replacement part for your model.
Disconnect the power from the TV and then remove the back cover from the TV and then look for the part number which should be printed somewhere on the back of the screen panel itself.
Once you have the part number, search online using the part number only to find suppliers.
Do not be surprised if you cannot find any or if you do that the cost of the part is nearly as much as a new TV.
If you decide to replace the TV, consider advertising the TV for sale as faulty screen - good for parts, to recoup some of the cost towards a new TV as people are always looking for replacement boards for various makes and models of TVs. Just a thought
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Francisco Navarro さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 16
今までの合計 712
