メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Envy x360 15m-bq021dxは、Hewlett Packard社によって設計されたノートパソコンです。
Windows Vista Boot Error
I am running virtual box and I installed Windows Vista Ultimate 64 bit. But after installation, it restarted and it kept saying missing file at location windows/system32/drivers/wdf01000.sys someone pls help cause I want to use vista
Edit: I tried everything. I did system repair, diagnose and everything
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
“It seems that this problem is because the wdf01000.sys file itself has somehow been corrupted.
All you should need to do is obtain a copy of the file from a working install of Vista. It is located
in C:\Windows\System32\Drivers. Just copy it to a CD or USB drive. Boot your computer from
a Windows Vista repair disc or from your Windows Vista Installation DVD. On the second screen
select Repair. Skip the automatic startup repair and click the option to open a command prompt.
Now change your directory to C:\Windows\System32\Drivers and rename your wdf01000.sys to
something like wdf01000.old. Now copy the wdf01000.sys file from your CD or USB drive. Exit
the command prompt and reboot the system. You should now be up and running.
NOTE: Make sure the version of Vista you get your file from is the same version. In other
words don't copy the file from a 64bit version to a 32bit version etc.”
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It is helpful, but I don't have any working computers with a CD or DVD drive. Also virtual box doesn't accept USB sticks.
さんによる
コメントを追加
回答を追加する
Kyle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 374
