メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Magic Bullet NutriBullet Pro 900 Watt Blenderは、野菜や果物をブレンドするために使用される小型ブレンダーです。
Nutribullet motor not activating
I have had my Nutribullet for two years and I’ve really enjoyed using it. A few days ago I noticed that it was getting a little bit finicky—I would press it down and turn it but would also have to jingle the cup around in the base to get the motor going. The motor might stop and I would have to finagle the cup in the base to get it running again.
Now, as you might have guessed, it has just completely stopped working. I put the cup into the base, press down, turn (it even makes a soft click sound), and it simply doesn’t run. To be clear, the activator tabs seem to move through their full range of motion and are NOT stuck.
I’m hoping to be able to fix this because I can’t find my proof of purchase so it won’t be elligible for any warranty.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
I took it apart and found that the plastic piece that holds the white tabs in place was broken. Without that piece holding the white tab in place, the white tab could not activate the sensor which in turn activates the motor.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Can you not just disconnect the red and black cables from the activator and join them together, eliminating the need for that activator to complete the circuit
さんによる
I would guess that would work yeah, and just plug it in to make it work, it would still auto stop (if it has that function). Or just unplug it or put a little inline switch on the power cord.
さんによる
コメントを追加
回答を追加する
Nathan Burr さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 50
今までの合計 2,929
