Help Removing Stripped BackPlate Screws?
So I had a new Backplate for christmas and was happy to finally replace old plate because of all the scratches, but when I was removing the screws I accidentally stripped 3... Do you guys have any ideas on how to remove those 3 stripped screws?
1件のコメント
You might be able to use tiny screw extractors like these that iFixit sells:
Precision Screw Extractor Set
Given that the casing is plastic, I wouldn't recommend trying to drill the screw out like you might do with a broken bolt in metal. I also don't think they make a set of easy outs small enough to get those Switch back plate screws out.
Technomancer さんによる 共有
