メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年に発売されたASUS X540sは、HDMIビデオ出力が可能なオンボードグラフィックス処理システムを搭載した15.6インチのノートパソコンです。
Laptop not turning on
Hey guys, my asus X541UA not turning on.
1.not turning on
2.not light charging indicator and not charging
3.sometimes its on, but turning off few seconds.and also connect charging and lights on
Could you please tell me what the problem is?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント:
If it works with the charger connected then the battery is defective.
さんによる
Thanks for replying. I removed battery but same thing happen.
さんによる
@tharaka maduwanthi
Tharaka, Do you know if the charger is good?
さんによる
Yes. I on my laptop without connect charger it not response.but after I connect to changer its on and immediately off.That happens twice or three times.after it not response connect charger and not light charging lED.
さんによる
@tharaka maduwanthi
Try this:
Remove battery.
Connect a different charger, say borrow a friends, with the same voltage.
Does the laptop turn on?
Does anything appear on the screen?
When troubleshooting you want to eliminate possible causes so in this case we are trying find out if the battery or the charger is the problem
If it is not the battery or charger causing the problem then it is something on the computer's main board.
さんによる
コメントを追加
1 件の回答
Hi Tharaka,
As you have encountered A PC shutting down suddenly, which is usually a sign of a power problem and can be extremely frustrating. This can cause you to lose whatever you're working on, but it may also be a sign of damage to the computer itself. Generally, when a computer powers down on its own it's due to the power supply, malware, overheating or driver issues.
Additionally, an unexpected shutdown of system can make your data inaccessible as well. The good way to overcome this problem and recover files after unexpected shutdown is by using a recovery tool that supports Windows PE.
Before locating the problem, make sure you backed up your computer all the time.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tharaka maduwanthi さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 30
今までの合計 1,244
