メインコンテンツにスキップ
2nd-generation magnetic AC power adapter for MacBook products, first released in 2012. Not compatible with previous generation systems. Available in 45W, 60W, and 85W versions.
26回答 すべてを表示
Replacing the T-Shaped pin with new one bought from China
Hi,
My MegaSafe2 adapters’ magnetic pin (T-shaped) has springes and I can see some of the pins are damaged due to short-circuit (probably water damage). Although the adapter works perfectly fine, one of the pins is stuck inside the magnetic clip. So every time I have press the magnetic clip to the MacBook charging point so it will touch and start charging. I decided to buy the new cable from eBay and I was thinking to replace it. However, I’m not sure if it is a good idea.
As I know if just replace the cable and not do anything with adapter then it should be fine! am I right?
Will it be an issue in the future with my mac if I use this cable?
Please guide me here! Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Best to get a new unit. Make sure its a REAL Apple unit OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
さんによる
コメントを追加
1 件の回答
ベストアンサー
If this charger has been previously shorted out I would not trust it to not damage my Mac.
I have repaired several of the cable but never one that shows signs of electrical damage.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Nirav Malsattar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 108
