Replacing the T-Shaped pin with new one bought from China
Hi,
My MegaSafe2 adapters’ magnetic pin (T-shaped) has springes and I can see some of the pins are damaged due to short-circuit (probably water damage). Although the adapter works perfectly fine, one of the pins is stuck inside the magnetic clip. So every time I have press the magnetic clip to the MacBook charging point so it will touch and start charging. I decided to buy the new cable from eBay and I was thinking to replace it. However, I’m not sure if it is a good idea.
As I know if just replace the cable and not do anything with adapter then it should be fine! am I right?
Will it be an issue in the future with my mac if I use this cable?
Please guide me here! Thanks!
この質問は役に立ちましたか?
1件のコメント
Best to get a new unit. Make sure its a REAL Apple unit OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Dan さんによる
