メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How can I fix a broken power plug?
My friend dropped my computer on the floor several years ago right on the power supply while it was plugged in. It worked ok for the next year but gradually got worse. Now it won't turn on at all. Is there a way to open the case and soder it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
ベストアンサー
Check to see if the tip of your AC adapter has broken off. They sometimes break off in the DC in port. If so and you can't get it out (very difficult) you'll have to do the replacement rab777 directed you to. I've had three customers who bought new AC adapters and then plugged them in with the broken tips still inside. That usually destroys the DC in port.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
That's true, a common problem, be sure to avoid that, usually tweezers or very small needle pliers do the trick.
さんによる
コメントを追加
Here's the DC-in repair guide.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I have the same problem, the power cord just quit and the light at the computer end stopped working. I checked the tip and it is good, I also tested it with a volt meter and I am not getting power (DC) out. Is there a way to take the end apart that plugs into the wall and check the bridge rectifie and transformer.
Thank you,
kevin
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
There are no user serviceable parts in the adapter. Opening one is reserved for NFL linemen.
さんによる
コメントを追加
Actually by follow the instructions for getting to the DC-in connection.
If you remove the rf shield
- at the back of the connector
- gently pull back on the top of the center tab
- form a gap that the tip will fit through
- you can push the broken power cord tip out the back of the connector.
Reassemble - get a new power supply - and away you go!
See my addition at the end of the DC-in repair guide.
(sorry for the bad picture)
picobrew
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brittany さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 7,288
