メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年5月に発売された、AppleのiPod Touchの第7世代モデル。最大256 GBのストレージとA10プロセッサを搭載。モデル番号はA2178。
How to fix a dropped iPod?
I dropped my Ipod on the ground about an hour ago and it is just the glitchy screen with the lines. How do I fix this techy people? <SOS>
Update: I let it die and then plugged it in and left it alone for a couple hours and it seems to be working fine now. There is still some slight screen flashing but it’s almost unnoticeable.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
7 件のコメント
Is the screen flickering still happening?
さんによる
slightly, yes
さんによる
Its possible you loosened the connection on your motherboard. There's no cracks or anything on the screen?
さんによる
Awesome glad to hear! It was totally the big UwU energy that fixed it.
さんによる
okay you have to be one of my favorite people in the entire world
さんによる
2件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
it seemed to have fixed itself, thanks for trying though, it means a lot to me. :>
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
thank you i would cry if it is broke
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you SO MUCH for this solution. My iPod was flickering after I dropped it, no matter what I tried. But I turned it off (powered off) and let it rest a few hours and the flickering was fixed. I’m so grateful 🙏🏻 . (Note: one hour was not long enough, was still flickering)
さんによる
コメントを追加
My iPod drop and it won’t come on
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
If you scroll up you’ll see that others have said they let it die and then plugged it in and left it alone for a couple of hours and then turn it on again, this fixed the problem. Their suggestions worked for me. Good luck.
さんによる
コメントを追加
it happens with all 7th gens i wanna believe, when you drop it it kinda like makes the phone panic and renderitself useless like some sad lil puppy on the side of the road. just hold the power,volume, and home button down which resets it and when it powers back on it may flicker but thats only because the LCDs were a bit burned for a bit but will ultimately go back to its normal state within a few hours. it depends on how long the phone was in that state. the longer the phone has the lines the longer the flickering and the lines will appear on the screen. I dont know what causes this but if anyone knows please tell me. im very curious
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
UwU_Person さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 44
今までの合計 6,052
