メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
SONOS PLAY 5は、Sonos初の、より広い部屋で、より大きな音を楽しめるオールインワンの音楽プレーヤーです。
Upgrading of, memory or processor, possible?
Is it possible to upgrade the memory or processor in a Sonos Play 5 Gen1?
I just received an email from Sonos saying,
End of software updates
In May, the following products in your system will be classified as legacy and no longer receive software updates and new features. This will affect your listening experience.
Legacy products were introduced between 2005 and 2011 and, given the age of the technology, do not have enough memory or processing power to sustain future innovation.
Please note that because Sonos is a system, all products operate on the same software. If modern products remain connected to legacy products after May, they also will not receive software updates and new features.
this seems very wasteful, (sending millions of speakers worldwide to landfill), to me as I have several of these speakers and they all work fine.
I spent a couple of thousand on these speakers, “they work perfectly”, and do not want to spend more money and send these to landfill.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
You do NOT have to throw away your speakers, you just won’t be able to get new features. Whatever works now as a feature will still work.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Not true. If Spotify (or whatever you are using for Music provider) upgrades its platform, it may no longer support your Sonos system that is not running the latest updates. If this happens, and it surely will, you will not be able to play music on your entire Sonos system, unless you remove the legacy devices and install the Sonos updates. At that point, your legacy devices are useless. They are effectively bricked.
さんによる 共有
Not, not true! Here we are over 1-½ years later and my gen 1 play 5s still work with Apple Music. As long as the Sonos S1 app works it should work. No one is making their platform to only work with Sonos.
さんによる 共有
I have many S1 devices and Spotify connects and plays with that system as it resides on my WiFi. Sonos could allow users to also access S2 devices. Sonos could even allow users to use both S1 and S2 at once on the same WiFi network either simultaneously or alternatively. Sonos has limited functionality here. Sonos doesn’t have a credible voice assistant yet they disabled Google voice control so now we basically have nothing. I was able to control my devices easily with Google. I literally do not use my S2 devices often bc Sonos has limited functionality in its new devices. There is no technical reason why S2 devices cannot be used on a S1 system. Sonos was visionary by going cross-platform, but now it has turned its back on that philosophy and it is sad to see. I can no longer wholeheartedly recommend Sonos bc it doesn’t work like it used to. Sonos should offer a credible paid music streaming option that is open platform and uploads/downloads Spotify play lists.
さんによる 共有
コメントを追加
回答を追加する
Flapdoodle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 1,152
