メインコンテンツにスキップ
Repair guides and support for the 27" Dell UltraSharp U2711 external display released in February 2010.
7回答 すべてを表示
How to use iMac monitor stand on VESA VGA monitor
I bought a Digitech Computer Articulating Desk Mount with bracket (model CW-2870) because its cheap. But I want to use it to mount a VGA monitor that is VESA-compliant ! How do you do that?
Update (01/13/2020)
This is the Digitech Computers’ CW-2870 from JayCar
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It looks like I need to improvise. Oh well, here goes:
  1. First, source a stainless steel strip to ‘construct’ an iMac-like mount
** This will then be mounted on the VGA monitor’s VESA-compliant mount
  1. procure some nut/bolts
  1. drill holes onto the stainless stell strip and attached it to iMac mount of the DigiTech articulating arm with the bolts.
  1. Secure these on to the VESA mount of the monitor
  1. mount the assembled iMac attached to the VESA mount of the monitor onto the monitor
  1. mount the monitor to the articulating arm. Secure with provided allen screw
All done !
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Hi @junmac ,
Pretty nifty. ;-)
How about you create a guide for others down the track who may not find this post
Dare To Repair: How To Create a Guide
Cheers.
さんによる
@jayeff
Hope you (and others) find this guide useful
How to mount a VESA monitor on an iMAC monitor arm/stand
Jun
さんによる
Hi @junmac ,
Thank you
さんによる
コメントを追加
回答を追加する
Jun Mac AUS さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 169
