メインコンテンツにスキップ
How to mount a VESA monitor on an iMAC monitor arm/stand
必要な工具と部品
  1. How to mount a VESA monitor on an iMAC monitor arm/stand, A desk mount arm for an Apple IMac: 手順 1、 3の画像 1 How to mount a VESA monitor on an iMAC monitor arm/stand, A desk mount arm for an Apple IMac: 手順 1、 3の画像 2 How to mount a VESA monitor on an iMAC monitor arm/stand, A desk mount arm for an Apple IMac: 手順 1、 3の画像 3
    • It was cheap so I bought 2 -- only to realize its for an Apple, not for a VGA (VESA) monitor -- too late !
    • So I improvised.
    • To mount a VGA monitor, I need to mount the VGA's VESA mount to the desk mount's IMac adaptor
  2. How to mount a VESA monitor on an iMAC monitor arm/stand, attach a metal strip to the IMac adapter: 手順 2、 3の画像 1 How to mount a VESA monitor on an iMAC monitor arm/stand, attach a metal strip to the IMac adapter: 手順 2、 3の画像 2 How to mount a VESA monitor on an iMAC monitor arm/stand, attach a metal strip to the IMac adapter: 手順 2、 3の画像 3
    • To simulate an IMac mount, cut the metal strip to fit inside the IMac adapter
    • drill a couple of holes on the metal strip that is big enough to fit a 1/8" x 12mm slotted round head nut and bolt
    • insert the bolt through the metal strip and the IMac adapter
    • secure with the nut
    • drill at least four holes and secure
  3. How to mount a VESA monitor on an iMAC monitor arm/stand, Attach the VESA mount to the monitor: 手順 3、 2の画像 1 How to mount a VESA monitor on an iMAC monitor arm/stand, Attach the VESA mount to the monitor: 手順 3、 2の画像 2
    • attach the IMac adapter's metal plate the the back plate of the monitor
    • secure the back plate onto the back of the monitor
  4. How to mount a VESA monitor on an iMAC monitor arm/stand, Attach the monitor to the arm: 手順 4、 2の画像 1 How to mount a VESA monitor on an iMAC monitor arm/stand, Attach the monitor to the arm: 手順 4、 2の画像 2
    • With the IMac adapter secured at the back of the VGA monitor, attach it to the arm
    • secure with screws provided
    • the desk mount should have been securely setup on the desk !
  5. How to mount a VESA monitor on an iMAC monitor arm/stand, Test and adjust the monitor: 手順 6、 1の画像 1
    • That's it !
    • Let me know if you have any questions or issues.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Jun Mac AUS
メンバー登録日: 12/16/15
181 ポイント
1ガイドが承認済み
コメント 1 件
Note:
For other non-Apple IMac monitors (like Dell, HP, etc.), you will need to use a VESA-adapter (or similar) to mount the IMac adapter that came with the DigoTech IMac Desk Mount Articulating Arm (CW-2870)
Jun Mac AUS - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 1,254
