メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Huaweiが2018年10月にロンドンで発表したMate 20。グローバルモデルのHMA-L29には4/6 GBのRAMと64/128 GBのストレージがあります。トリプルカメラ構成、4200mAhバッテリー、背面に指紋センサーを備えています。
Is my phone hard bricked?
Hi, all just wondering if my phone is hard bricked or not since I can’t find any information on my specific device it won’t turn nor vibrate the red light goes out and return after 10 seconds press of power button and the hard rest process. Is there any solution to it or is the phone dead?
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Try this link and check if you can force flash the stock ROM
Here’s a link to the available ROMs
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
Hi, so my phone is hard bricked even though I didn't mess around with the software?
さんによる
Also, How will I be able to flash ROM when there no connection to my pc?
さんによる
Hi,
Does the phone indicate that it is charging properly when the charger is connected?
You don't use a PC connection.
When you do a "force flash" the firmware files are stored on a SD card which you have pre-loaded (load into the root directory of the SD card) from a PC or phone or whatever and then you insert the SD card into the phone.
It is all there in the instructions
さんによる
well, the condition regarding the charging thing it's weird the light comes on but now it flashing and when holding the power the phone vibrates but then the light goes back to solid again furthermore when it vibrates the screen comes on showing low battery but that's all once the solid light comes on the phone goes back the original condition black screen and no response.
Thank you for your help.
さんによる
Hi,
What happens if you just connect the charger and do not press any buttons?
Does it charge smoothly up to full charge or does it stop charging, start and stop etc?
Have you tried either starting the phone or doing a hard reset with the charger connected in case it is a faulty battery that is the cause of the problem?
Can you get into the phone's recovery menu area OK with the charger connected and switched on?
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Tony Vox さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 3,025
