メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola Moto Z4は、MotorolaのMotoコレクションで、モデル番号はXT1980-3およびXT1980-4です。 5G対応です。
Screen replacement tools ands part
Cracked screen I need parts
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
6 件のコメント
InjuredGadgets.com
さんによる 共有
So where is the guide to fix it?
さんによる 共有
Could not find any guides there.
さんによる 共有
@ruppertj It opens up just like the Z3, but the ribbon is on the right side. I would recommend disconnecting the battery first.
さんによる 共有
Well this was a day late and a dollar short, It would have been helpful if the cause of the screen separating from the body was caused by the battery expanding from gas build up. This did not effect the battery performance but it surly is the cause of the screen separation. This should be noted as the main cause of screen separation and the screen cannot be replaced until the battery is replaced. I wasted two screen replacement kits Z2-Force and Z4 because of the batteries had expanded. This was the cause in my Z2 and Z4 screens to separate.
さんによる 共有
1以上のコメントを表示
コメントを追加
3件の回答
最も参考になった回答
Hi,
There are suppliers online.
Just search for Moto Z4 LCD part with tools to get results.
Here are just two suppliers found on a quick search
example 1
example 2
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
InjuredGadgets has the screen as well but I would get the Genuine and not the other cheaper one from them.
さんによる 共有
コメントを追加
I think iFixit sells a wide range of tools and replacement parts, if that’s what you mean.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
If you read carefully no that not what I mean ...moto z4 is the title
Screen Replacements tools and parts ..that the subject...and finally
Cracked screen ,,I need part that's the message..
さんによる 共有
コメントを追加
Both of those examples are LCD screens which are for the cheaper Moto z4 play. The original Moto z4 has an OLED screen. Make sure to look out for this because as far as I've researched, they are not compatible with each other.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Alexandre Domon さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 34
今までの合計 3,704
