メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iRobotのロボット掃除機、Roomba 980。2015年9月発売。
Trash bin sensor broken
The small shiny metal bumper inside the trash bin housing has broken so the bin and roomba are not in agreement that the bin is installed. How do I get a new bumper installed?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Hi @roombasrock1328 could you post a picture in your description so we can get a better view of what your problem is? And when you say agreement do you mean alignment? The trash bins sensors will be located where the bin is inserted towards the back on the left and right side of the opening and they have a slightly purplish tint to them.
Best regards.
さんによる 共有
My bin continually comes out of the I roomba . I cleaned the sensors and cleaned everything near the bin but it continues to happen. Is there a place near me where I can take it for repairs?
さんによる 共有
コメントを追加
6件の回答
最も参考になった回答
I have the same problem.
画像
. How can I get a new contact?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Just figured this out. Take a small piece of tin foil and fold it up, place it on top tof the broken sensors and jame the bin closed. The foil hot wires the system and the robot detects the bin.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I'm having the same problem, Glenn. Did you manage to fix it?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Did you get this working eventually? I have the same issue - if you can remember which video you used to disassemble any chance you could post it?
Cheers!
さんによる 共有
コメントを追加
I bent the remaining piece of metal and put the bin back in carefully. This is working but I wouldn't call it fixed. It's disappointing that you can't get a new contact to install.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I managed to find the contacts on eBay! I've disassembled the Roomba with the help of a YouTube video. When the part arrives we'll see how it goes!
さんによる 共有
What did you buy specifically on ebay? A sensor or the metal contacts? Also what you tube video did you use? Im in the same boat error 14 on my 900 series
さんによる 共有
コメントを追加
Same problem here. So frustrating!
Anyone have a solution to replace these metal contacts for a 980?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Tape a piece of tin foil across the contacts. Acts as a jumper, replace when it gets worn out.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Colby さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 56
今までの合計 2,875
