メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ASUS Zenbook Flip S UX370UAK(旧) / UX370UAR(新) 2in1コンバーチブル、ペン対応、指紋認証
What screw size is it?
I have Asus Zenbook ux430u and I want to replace some parts but I don’t know which screwdriver I should use.
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
TORX T5. You'll find this in many kits.
さんによる
コメントを追加
1 件の回答
ベストアンサー
T5 or T6 for the Zenbooks - it depends on which one you have, so I would get both just in case. It isn’t a TR Security at least, so that isn’t an issue. More then likely it’s T5 because that’s historically what Asus uses in the Zenbook, but T5 and T6 are very similar looking to a point on devices like this, it’s best to have both. It uses Phillips #00 screws like nearly every other laptop in the PC sector internally.
I would also get the 64-bit driver kit just in case it’s something obscure even what information I have doesn’t apply. You’re better off with the 64-bit driver kit since it isn’t that much more, if you want to save a few bucks, the Marlin screwdriver set will work. This only has the T6, so you’re taking a chance on if it will work or not as well.
iFixit's 4 mm aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top — plus 64 essential precision bits to tackle sneaky security screws.の画像
製品
Mako Driver Kit - 64 Precision Bits
$39.95
Torx Security precision fixed blade screwdrivers in a handy case with built in sorting tray.の画像
製品
Marlin Screwdriver Set - 5 Torx Precision Screwdrivers
$21.95
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
thank you very much:)
さんによる
does anyone know what the actual size of the screw is as well? I'm trying to find replacements but I can't tell what the size is.
さんによる
@Talal Hasan Usually Asus is T5 - look up the model and you'll know right away.
さんによる
Guys, I lost them after I removed the screws. Can you tell me their model number? (like M2 * 4). There should be two kinds of screws on the D side.
さんによる
@zpp eBay. Buy a bunch of them for a few bucks, but keep in mind unless you seek out T5/T6, they will be Phillips.
さんによる
コメントを追加
回答を追加する
Anton さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 91
今までの合計 19,428
