system not starting up when turned on.
When i turn on my macbook pro, it begin to load up and cuts off before it complete.
@luciofelix3 - The AC charger has a connector which connects to your system this connector is called a MagSafe within the connector is a charging LED:
It will glow either Amber or Green
What is yours doing? Or is yours not lit at all?
このアンサーは役に立ちましたか?
Ok well as usual, it starts off as green and turns to amber.
@luciofelix3 - Good! Now let it charge until it goes back to Green this may take a good four hours.
Ok will do and I’ll let you know when it’s fully charged
good day, so i charged it and now i'm getting a folder with a question mark flashing instead of the apple sign when starting up.
@luciofelix3 - Good! Thats heading on the right direction.
Let’s try this restart your system again and this time hold the Option (⌥) key to gain access to the Startup manager.
Do you see a bootable OS listed? If you do select it using the keyboard arrows are you able to get to your login window?
Reference: Mac startup key combinations
このアンサーは役に立ちましたか?
You thinking HDD flex cable @Dan? Initially I though corrupt or failing HDD but now the blinking folder makes me think to go right to the cable it's self.
Do you see a bootable volume using the Option key??
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 68
5 件のコメント
What is the color of the MagSafe plug Amber or Green?
Dan さんによる
Also, Do you see anything on the screen like the Apple logo and the loading bar, then it cuts out before it completes?
Joseph Hughes さんによる
Yes the apple logo comes on and it starts loading then cuts off about 1/4 of the way
Aaqil Felix さんによる
@luciofelix3 - And what is the color of the MagSafe LED ??
Dan さんによる
Forgive me, but I don’t know what is the MagSafe LED
Aaqil Felix さんによる
