メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Series 3シリーズのPCであるNP300E5C-A09USは、1366x768の画面解像度を備えた15インチノートパソコンです。軽量でありながらパワフルなポータブルコンピュータを探している方にとって、素晴らしい選択肢となります。
No BIOS or OS
I have a old Samsung NP300E5X-A0ANG (which a model number IFIXIT didn't have)
I had Linux Ubuntu installed on it which for some reason stopped working so i decided to wipe the drive and start fresh but i come to realize it no longer has BIOS at all
So i have no way of getting into a one time boot menu no idea what button(s) i have use to flash an old .bin file i apparently had in Google drive (i have a account were i only put drivers and firmware etc. On it in case i ever need it)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
I think you are saying that you can not access the bios…it must have a bios if it was booting but perhaps the access to the bios is corrupted? I would take the unit apart (look for tear down videos of similar models or search for some instructions…I had to do that with my obsolete and uncommon laptop and somehow found enough info). You’ll need to locate the CR2032 or similar bios battery holder on the motherboard and replace the battery.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Tried that didn't work and yes what i mean is i cant access a Bios anymore
さんによる
コメントを追加
The problem is caused by UEFI boot after installing Debian Linux. The Samsung BIOS is faulty by default and if I know well it is not yet fixed by the manufacturer. I had the same problem. The only solution is BIOS Flash. It can be done if you buy a programmer like CH341A. There is a great tutorial how to make it: ++https://jensd.be/980/linux/bios-or-spi-p...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi! I have an NP300E5C, ita version. And yeah, same issue. After some long researches, it came out that installing linux on these laptops, corrupts the NVRAM. For this reason, the bios becomes not accessible anymore, and the os doesn't boot anymore. Other drives won't boot too. Try to enter the boot menu pressing some random F keys. If this doesn't work, unfortunately you can fix only by replacing the bios chip (costs around 15€ on ebay, not really expensive)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sam Tahir さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 28
今までの合計 1,974
