メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The BlackBerry Key2 (stylised as BlackBerry KEY²) is a touchscreen-based Android smartphone with a portrait-oriented, fixed (not sliding) integrated hardware keyboard. The Key2 LE is produced by TCL Corporation under the BlackBerry Mobile brand name and is available in 3 colours. Includes models BBF100-1 (EU, Africa, AU); BBF100-2 (Canada, US, LATAM); BBF100-6 (ME, APAC, India); BBF100-4 (China).
How do I fix an antenna broken off the mainboard?
Hi
During a screen replacement, the “male” part of this blue cable (i think it’s the antenna) did break off the mainboard (slot 2) and is is now “stuck” inside the cable.
How can I replace the “male” part on the mainboard? Do I have to solder? Because I’m not that experienced in solder tiny things so I’m kind of afraid to break even more.
The local smartphone doctor would charge me $70 for a repair - is that a fair price or way too much?
Kind Regards
Cedric
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
So it's not actually stuck, hence the quotation marks around that?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
You can do a right repair: Find the broken piece and solder it back, or Order a new piece and solder it back, or take the piece from a donor board and solder it back.
You can do a quick repair: Remove the head from the cable, solder the outside cable to ground and the internal cable to the signal pad.
Is a five minutes task, but you need to have the equipment and the knowledge to complete the task. From $30 to $50 I think it’s OK
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I think this is horrible advice. “You need the right equipment…”. Yes! This is a microsoldering job, and if you muck it up, the motherboard is toast. I paid $150 to fix mine, at Microsoldering.com. This failure apparently happens often.
さんによる
Agreed. I have soldered these u.fl connections. They are very small, difficult to solder. And easy to cause a short circuit.
さんによる
@Bob Haberkost $150?????????? Jesus, I’ve soldered these on for £5 😂 Some places really take the mick.
さんによる
guys, soldering antennas is stupid! I think I've already fed a few things in my 44-year-old life. this doesn't work - I fried the parts around in a few seconds - key2 written off - second attempt a couple of months later - conductive glue, then pour it hard in epoxy - the only option! all key2 have a huge defect in the quality of the male connector - before you start anything, it's better to stick it hard on the MB - it will save a lot of problems and worries
さんによる
コメントを追加
回答を追加する
Cedric さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 23
今までの合計 1,822
