replace keyboard on hp laptop
I am looking to replace the keyboard in my hp 15-db0019au laptop. can anyone help please?
I can’t find this specific laptop here
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
The keyboard in your laptop is part of the top cover assembly and you’ll have to completely dis-assemble the laptop to get to it.
Here’s a link to the Maintenance and service guide for your laptop, taken from this webpage.
The manual details how to dis-assemble the laptop.
On p.76 you’ll find the the part numbers and the country specific part number suffix (if required) for the top cover/ keyboard assembly.
If you search online using the appropriate to your model variant part number (and country suffix if required) only in the search term of your browser you’ll get results for suppliers of the part.
Usually the part number is printed somewhere on the underside of the assembly if you wish to verify that you are ordering the correct part.
このアンサーは役に立ちましたか?
wow! There's a lot of parts that need removing
will i need to put more thermal material on?
Hi,
Check how "dry" it looks.
If it seems crusty and flakes off if you gently pry with a fingernail, clean it all off and refresh it.
There are plenty of videos on YouTube that show how to do this on a CPU or go to p.57 onwards in the manual to see how.
Thankyou so much
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 417
