メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1.5 GHz Core Solo、1.66 GHzまたは1.83 GHz Core Duo、あるいは1.83 GHzまたは2 GHz Core 2 Duoプロセッサを搭載。 2006年初頭から2007年中盤までの、Intelプロセッサを搭載した初期のMac miniモデルについて解説します。
no usb
USB not working at all. mac fires up but not a peep out of the USB
tried plugging different USB devices in which have lights on them but doesn't seem to be power available
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
If one of these answers fixes your problem, please go to that answer and hit the "accept" so that we can remove the question from the unanswered list. Thanks so much.
さんによる 共有
I have the same Mac mini and suddenly the usb ports stop responding. The only way I have managed to make them work is through a usb hub that has external power. It seems that the problem is that the usb ports do not supply any power. Have you find a solution?
さんによる 共有
コメントを追加
3件の回答
ベストアンサー
According to what system you are running different IOUSBFamily are needed. You can look it up here for a detailed decription of the problem and which files are needed:http://developer.apple.com/hardwaredrive...
or
just reinstall your system and the updates.
Debug releases of the IOUSBFamily kernel extension are used to provide information about USB device and interface detection, driver and interface matching, driver loading and information generated as a result of normal and abnormal conditions.
Unique debugging versions of the IOUSBFamily kernel extension are available for the different Mac OS X releases. It is important that you install the correct version of the IOUSBFamily kernel extension or you might find that the system will panic during startup or that your USB keyboard or mouse may not function properly.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Looking at the teardown guide the USB ports are soldered to the logic board. Therefor my first step would be to run disk repair. If that didn't help I would make sure I had a good backup--reformat the drive and reinstall the OS. If still no luck you may be looking at a bad logic board. I usually recommend getting an appointment with a Mac Genius for confirmation before buying a expensive part. Ralph
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If you go to /System/Library/Extensions/ do you see IOUSBFamily.kext ?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
just looked in Extensions folder IOUSBFamily not there
さんによる 共有
コメントを追加
回答を追加する
mat さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 2,253
