メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2006年半ば / モデル番号: A1181 / ブラックまたはホワイトの筐体 / 1.83または2.0 GHz Intel Core Duoプロセッサ
New hard drive input/output error
My old MacBook hard drive died and so I installed a WD 250GB 5400RPM SATA HD myself but when trying to erase it I get a input/output error and I cannot seem to partition it. When I try to reinstall my original Tiger OS X the 'select a destination' step is blank and there is nothing to select. I'm not worried about the old HD as I had mostly everything backed up - I just want to get this new HD up and running and get my MacBook fixed! I starting to go through cold turkey without it... please help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
ベストアンサー
Use the jumpers and set it down to 1.5 GB. Usually pins 5 & 6
Go here and look for SATA Hard Drive Jumper Settings on the first page:
http://www.wdc.com/wdproducts/library/ot...
UPDATE 4/8/12 Here are the settings. The two pins on the right should be jumped
画像
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Forgive my ignorance but I don't follow..
さんによる
Thanks for the help, but I don't think that is the hard drive I have bought. Mine only has 4 jumper pins and no shunt or anything already on it. Is the problem something to do with the fact that the software isn't reading the hard drive as a 250GB, rather it reads the drive as a 1.8/2TB drive?
さんによる
Having found others with this problem, I think you are right in that it needs a jumper shunt, but how can I get one to put on?
さんによる
All old IDE drives had jumpers. Any computer repair place will have bottles of them or that old PC in the garage will have one.
さんによる
Hi thanks for the help - I put a jumper on 2 of the pins using these -
http://www.maplin.co.uk/2.54mm-0.1-inch-...
I'm not sure if they were the right fit. I still get the I/O error. This is the HD I bought and my MacBook is a 2006 model.
http://www.scan.co.uk/products/250gb-wes...
Should I try another HD? Cheers.
さんによる
コメントを追加
Hi did you find a solution for this in the mean time? I am having this problem too....
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have the same problem.
i bought a new 500gb wd hard drive and it didnt work. i thought its the hard drive cable which is broken, so i bought a new one and replaced it, but the "input/output error" is still there.
my hard drive is also read as an 3tb drive by the mac os x install disc.
i tried to format it with "gparted" (boot cd) and it did work, but mac os x shows the same error.
whats wrong?
i dont get it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Having the same exact problem. After ordering a new hard drive, I'm ready to give up and order a new computer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just had this issue.
Hard drive died, bought new hard drive, didn't work. Replaced hard drive cable, formatted HFS+ using a second Linux machine, and then i started getting the "Input/output error" that you guys are having.
Two sets of discs came with the MacBook. One set is the "Mac OS X Install Disc 1/2" CD's (they still make CD's?). The other is a Leopard OS X Install DVD. The CD's gave me the I/O error and recognized the 500GB drive as 3.64TB. The DVD had no issues at all. Try to find that DVD :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
J Ernesto さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 43
今までの合計 10,101
