メインコンテンツにスキップ
Released September, 2014. Inspiron 15 3542 4th Gen Intel PDC
17回答 すべてを表示
締切られた回答
Why does my laptop always go dead so quickly?
I love this laptop dearly it was free and i replaced the keyboard hard drive and other things throughout the pc. But it will bog down every time i go to use it after using it previously. Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
Hi @iphonehater1 , what does it mean "go to use it after using it previously"? What does "go dead so quickly" mean? Please, describe more your issue, what was the state before? What type "dead" issue? What did you do before it goes down?
さんによる
コメントを追加
2件の回答
Hi! joshua morgan it seems that your Battery is Defective. try to replace it or use a Multimeter to your Laptop Battery. using this guide. マルチメーターの使用方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
as for performance, i would recommend keeping drivers updated and removing system bloat. a defrag will do wonders if you havent switched to an ssd. plus, if you're really ambitious, linux mint can be a nice lightweight os.
as for battery capacity, press f12 on boot and there is a self diagnostics mode which should show the remaining capacity of the battery. if its below say, 50%, id probably replace it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 19
今までの合計 101
