メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
低音域を耳に伝える汎用オーディオデバイス。
Only 1 amp working!
I have 2 amps set up everything is wired up good I checked all my volts with a multimeter ,and everything checks out . But it seems that I can only have 1 amp wired to get any power . I wired each of my amps to 1 power source and each amp started up so is there a reason I can’t set up my highs amp and my bass amp ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@jaimeibarra what make and model are your amps. How did you wire them up? Schematic or picture?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
There might be an issue with the remote turn-on lead. Some radios don’t provide enough current out of the remote lead to turn on multiple amps. Try running 12V from the battery to both of the amps remote turn-on leads and see if they both turn on. If that works, then you can use a relay connected to the radio’s remote turn-on lead and switched 12V power to switch your amps on. Also check to see if you get a voltage drop when both amps turn on at once. It’s possible that one of the amps is going into protection mode due to under-voltage. There could be a wiring, car battery, or alternator problem that isn’t supplying enough current for all your car’s electronics.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jaime Ibarra さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 33
今までの合計 432
