brush Head not turning
The brush head on my dyson is not spinning. No blockage or tangles. Think it’s the motor. Is this repairable?
If the suction is ok, its probably due to hair being caught under the motorised head rotator.
# Use a pair of tweezers to remove any hair, you’ll be surprised as to how much there is.
このアンサーは役に立ちましたか?
I have this problem but the brush is clear. It appears the power for the little electric motor is not being sent by the main unit down the two pins. How do I get inside to see why power isn’t getting through?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 2,978
Hi,
With the brush head removed from the vacuum cleaner, do you get sufficient suction at the end of the rod that it attaches to?
Is the battery fully charged?
Is the filter clean?
jayeff さんによる
Does anyone know where to get a replacement motor?
TyN さんによる
For parts from my experience eBay is 9/10 the best place
HelloMacOS さんによる
