メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
トヨタのベストセラーコンパクトカーの第6世代(E90)です。E90 Sprinter、Holden Nova、Geo Prizmとしても販売されました。この世代はサブコンパクトカーとして分類された最後のCorollaであり、また全面的に前輪駆動(FF)または全輪駆動(4WD)となった最初の世代でもあります(後輪駆動のオプションはこの世代で廃止されました)。
this is my problem
first problem of my corolla Toyota is grounded, the battery is becoming weak when engine stop. i used to recharge my battery everyday. when i start, it will start, but when i did not start the engine within three days, the battery would weak and cannot afford to start the engine. until now ,its about one month that the engine did not start. please advise me on how to repair
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント:
i dont know on how to answer my question.
さんによる
Hi,
If you can charge your battery enough to start the car, once the car has started use a Voltmeter to measure the voltage across the battery terminals with the engine running.
It should measure between 13.8 -14.5V DC.
If it measures less than 13.8V DC then there is a problem either with the car's alternator or voltage regulator and the battery is not charging when the motor is running.
If it measures more than 14.5V DC it is overcharging the battery which could damage the battery.
Be safety aware when you do this as the engine is running!
Also ensure that the emergency brake (hand brake) is firmly applied
さんによる
My Engine not start.please help me
さんによる
Fuel tank is full of soil and rocks
さんによる
コメントを追加
1 件の回答
We need the exact year of your car, also the battery may be shorted internally or have a dead cell so you should charge it up fully, to save time, then take it to your local auto parts store for a free test. If it is good then we can help you find the parasitic drain in your car. This test will involve an amp draw test which will use a multimeter, do you have a multimeter that can test amps? If you have one, do you know how to use it properly to test amps? Here is some help.
https://www.youtube.com/watch?v=KF1gijj0...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Teodoro Achas さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 23
今までの合計 928
