メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JXD S7800Bは、オペレーションシステムにAndroidを採用し、コントロールを内蔵したタブレット兼ゲームコンソールです。
Replacement Joystick Hats Needed
Where can I get replacement joystick hats for the JXD S7800b in the UK or evenb US if they ship to the UK? I tried to order from the official site but after a month they never arrived and now they’re ignoring my emails.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I seriously doubt that the JXD official was out of service back in 2017.
It appears that the joystick hat can be unsoldered from the PCB and a replacement soldered back on.
So I think the best way is to get a cheap used one and replace the hat from that one to the current one if it runs well. As there are really cheap bargains out there.
https://www.keeboshop.com
https://www.ebay.co.uk
To save you more money, I think you can also find substitutions/alternatives that can fit your device.
Hope my answer helps you.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
If they were out of service 2 years ago then they are back up. Their site is still up and taking orders. And I need the hats not the joysticks. There is nothing to solder.
http://www.jxdofficial.com/jxd-s7800-spa...
さんによる
@mforcevirus Yes, I mean that you can just take the hat from a cheap one, as there's hardly supplier for the separate part. Othrewise, waiting for jxdofficial reply would be the only way. Thank you!
さんによる
Ah I see. When you mentioned soldering off from the PCB I thought you meant the actual joystick and not the plactic hat that just pulls off. As for JXD, They were quick enough to ask me to prove that I had order details but in the past few weeks they have been ignoring me so I opened a paypal dispute.
さんによる
@mforcevirus Or maybe you can also try to find a substitution of the JXD joystick hat.
さんによる
I did try searching on ebay but most of what I found was for the Playstion controllers. None of the ones I've search for give much detail about the size and on the S7800b they sit on a very thin pin.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
mforcevirus さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 27
今までの合計 593
