メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年11月発売、モデル番号RCT6077W2、4GBストレージ、7インチタッチスクリーン。
Turns On, Wont Work?
Recently I had rediscovered this tablet and decided to use it for work purposes. Not even a day later a friend of mine thought it would be funny to smack the think out of my hand and onto the hard pavement. Miraculously, The only physical damage that could be seen is a slight crack through the left part of the screen itself. However when the actual device itself is turned on the entire left side is simply unresponsive while the right works perfectly fine. I’v already tried most of the normal tips and tricks (turning it off and on, factory reset, etc,) but nothing seems to actually be working. What would be the best course of action?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
I’m assuming that the LCD screen is OK, i.e. full display on entire screen and that the touchscreen (aka digitizer) is not responding on the left side. Is this correct?
If so then the touchscreen either has a loose connection to the systemboard due to the fall or it is faulty (you mentioned a small crack) and needs to be replaced as it cannot be repaired.
Here’s a link to the ifixit RCA RCT6077W2 guides, which may be of some help in gaining access to the digitizer’s motherboard connection so that you can check if it is OK or not and also the screen if you need to replace it.
Here’s a link to just one supplier for the replacement part.
It is shown only to give you an idea of the cost of the part and what it looks like. There are other suppliers online that may suit you better. Just search for RCA RCT6077W2 touchscreen to get results.
I suggest that you also bill your friend for the cost of the repair (and your time). After all this is their fault.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks again, I do appreciate it
さんによる
コメントを追加
回答を追加する
Someone Noone さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 294
