メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年3月発売。モデル番号 SM-J727で識別可能。
J7 Crown Black Screen
I have a J7 Crown S767VL that has no screen display it stays black phone is still powered on and when I try to hard reset it doesn't fix the issue I have tried to power off by holding power + volume down button for 20+ seconds and after about 15 seconds of holding buttons it vibrates every 1-1.5 seconds and does not power off. I have been attempting to factory reset with black screen with no luck and have exhausted my options available online. Please give me suggestion(s) on what I can do it is a straight talk phone.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
1 件の回答
It sounds like an LCD fault. Has the phone been dropped in water or dropped on a hard surface?
このアンサーは役に立ちましたか?
スコア 0
12 件のコメント:
I do not believe it has gotten wet or dropped, it is in pretty pristine condition as far as I can tell I was thinking it was a corrupted firmware issue
さんによる
You will need a new LCD if you haven taken phones apart then you can replace the screen yourself or take it to a repair shop. It will be a whole lot cheaper replacing it yourself if you do that go here https://www.amazon.com/Replacement-Digit...
さんによる
Is there a way to try to perform a factory reset without the ability to boot in recovery mode and being unable to do it through settings?
さんによる
Hope this helps
さんによる
Yes if you have a computer
さんによる
7件以上のコメントを表示
コメントを追加
回答を追加する
Corbin Dallas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 1,936
