メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
中国の多国籍エレクトロニクス企業であるTCLが製造するテレビ。
TCL Half of screen darker
do I need to replace leds when screen darker on half of tv
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
最も参考になった回答
Sherri B  it is possible that this is an LED backlight array issue. Post some images of what your screen shows. Use this guide iFixitでの質問に画像を追加する方法 for that. You also want to try to reset it. Remove all input sources as well as soundboard etc. Then unplug the TV. Either hold the power button down for a few minutes or keep the set unplugged for something like 30 min. Then connect only one video source ( a local source like DVD/BR/ or Game console would work. Stay away from cable or sat box for now since they can actually be part of the problem).. Then plug the TV back in and see if that made a difference. If it did not you will have to remove the back cover from your TV and take a look at the board. Check for any obviously damaged looking parts and reseat the interconnect cables. Post some pictures of the boards as well. You will need a multimeter to check the LED connector voltages etc. TCL is still a bit of an off-brand make so there are not a whole lot of schematics etc. available so we need to rely on your images to see if we can find out what's going on.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
May be? Just open and see if there are any “leaked capacitors”…
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I repaired a 43P20US TCL smart tv right side darker and eco setting on would make the screen go black at 4 sec intervals. Checked power supply okay. Secondly I decided to go straight to TCON board it was pretty dusty so decided to clean connections with pencil eraser. Retested and solved both issues. Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
left screen is darker coler good. just got replacement boards from shopjimy.tv works but still darker left screen.i do think the tcon board was bad.it is a better pic……but no lines in the screen just little darker on the left.the new boards and all was replaced pic not disorteing now…is the update bad??????????????????????????????
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
yep might be just that///////
さんによる
コメントを追加
回答を追加する
Sherri B さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 22
今までの合計 12,428
